I have a 400Watt power supply from iMicro, which I substituted for the Dell OEM power supply.
It used to work fine for about an year, but recently started to make growling noise when it's switched on. The noise remains for about three minutes and goes away.
Is it a sign that the PSU needs to be replaced? I don't want to make an expenditure unless absolutely necessary, but at the same time don't want to save a few bucks now and spend a fortune on replacing a damaged motherboard either.
