Hello,
My system has encountered a problem. The system has been randomly shutting down and/or restarting. Last night, the system hung and I had to do a reset. From there, it would start to boot, but hang where it would normally show the list of drives on the screen, and gives you the DELETE or F8 option. After several restarts, it never booted past that. I tried the DELETE & F8 keys with my USB keyboard, but no response. I then hooked up a PS/2 keyboard, and rebooted, still nothing.
I finally cleared the CMOS and tried rebooting. At this point, I get to the ASUS Ai splash screen, but still no response to the keyboard (USB or PS/2).
My BIOS was 1903. I have been running the ASUS M2N32-SLI Deeluxe, AMD5000+ black edition, OC’d to 3.01Ghz. 6 GB RAM. 1GB 9800GT+. Everything has been in place for quite some time. I can tell that my HDD is spinning, so I want to say that it is still good (although I will need to test in different system). Because my system is unresponsive to keyboard commands, I suspect there is a failure in the motherboard, rather than CPU, HDD, RAM, GPU.
Does anyone have any thoughts as to whether the mobo is the problem (and if so, any suggestions on fix)? Any further testing? Since I can’t get the keyboard to respond, I’m not sure how I could do anything else.
Thanks for any feedback.
