Archived from groups: comp.sys.laptops (More info?)
Hi All,
Does anyone know of a good list of laptops and their respective power
requirements (amps/volts)? I am looking for a laptop that draws as little
power as possible.
Regards,
Paul
Sponsored Links
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> power as possible.
For what purpose?
Most laptop adapters pull in normal AC, do you have a specific purpose
in mind for what you need a laptop to pull and how are you pulling it?
David Wade Hagar AKA Cyclops
http://members.cox.net/dwhagar
http://www.livejournal.com/users/dwhagar
http://genius-of-lunacy.blogspot.com/
"It's sick, but it serves a purpose." - Bill Cosby
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (MingW32)
Comment: http://members.cox.net/dwhagar/personal-key.asc
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iEYEARECAAYFAkHSpNYACgkQbPwf4VgkRDvUkgCfcZpC1gsUMKxbUVyY718kPc2n
rXsAn0ilaO2YKSl8Ciwbr289iUMAPRU/
=PamV
-----END PGP SIGNATURE-----
Reply to Anonymous
little
> > power as possible.
> For what purpose?
I currently use my laptops on a yacht. I need a new laptop and would like to
find a comparison between the power consumption. My old Fujitsu (3.36amps/16
volts) for example draws a little under 54 watts while my new Centrino based
Toshiba M200 (4amps/15 volts) draws 60 watts. I need to get power
consumption as low as possible, I do not want to add more batteries.
I have looked at Micro ITX type technology and have a quote for one system
from G2 Digital Video(http://www.g2digitalvideo.co.uk/) that will draw 35
watts less the screen. The only real issue there is that I loose the
flexibility/portability of a laptop.
Regards,
Paul
Reply to Anonymous
If you want the maximum efficiency, consider making a special
hollowed-out battery containing a regulator that taps off your yacht's
batteries directly, rather than going through an inverter to bring it
up to 110VAC and then a switchmode power supply that brings it back
down to the laptop's DC input voltage.
My HP ZE4805 (2.1GHz Athlon XP-M) pulls about 1.75A @ 16V out of the
battery, depending on what exactly you're doing of course. That's under
30W including screen.
Reply to Anonymous
Hash: SHA1
Well... My Ispiron 1100 here draws 20V/5.4amps according to the back of
the AC adapter, but I think that goes down dramatically when the
laptop's battery is charged. You should be able to see power
consumption on the detailed specs of a laptop.
iEYEARECAAYFAkHTEWkACgkQbPwf4VgkRDuS8ACeIkHpgcLzJNlQNbEo11TQeFfS
1fIAnAyAnspAkRHOEZ0UNw343bZxdpsz
=8Yvq
Reply to Anonymous
How about an external battery recharger. maybe via solar. Running the laptop
only on battery and recharging the other? Solarcells are anyway a good think
on a yacht where you have lots of space for it..
Reply to Anonymous
<larwe@larwe.com> wrote in message
news:1104331215.648450.187420@f14g2000cwb.googlegroups.com...
Can you please post a little more information on what it is you have done? I
don't anticipate dropping below 11 volts and when charging the alternator
pumps in around 14.6 volts peak. In terms of a DC regulator I assume ( maybe
incorrectly ) this to be pretty standard.
Maximum efficiency is a must.
Many thanks,
Paul
Reply to Anonymous
That's what those car/airplane adapters do, they convert 12v to
whatever voltage your notebook needs in a more direct manner.
If your ultimate goal is still tetherless, then look for a new
notebook with a long battery life (with standard battery), that's a
good indication of how efficient the notebook is. Start with the
lowest clock speed u can live with, then go from there.
Reply to Anonymous
I'm saying, supply the laptop through its _battery_ input terminals,
not through its _charger_ input. This will necessitate buying a
disposable battery (a dead one off eBay is fine). Remove all the cells
and the on-board gas-gauge circuitry so all you have is an empty
housing with the battery connector inside it. What I would then do is
put a connector on the outside of the battery housing, routed directly
to the +ve and -ve terminals of the battery connector. So what you now
have is an empty fake battery that you can put in your laptop, which
has a connector somewhere accessible on the outside. Basically you're
bringing the laptop's proprietary, inaccessible battery terminal
connector out to a standard connector that's accessible on the outside
of the machine.
Then build a small boost converter that takes your yacht's 11.0-14.6VDC
rail and brings it up to the nominal battery voltage expected by your
laptop. You can _probably_ find something off the shelf to do this,
although it is more educational to build your own :) Connect this to a
cable with a connector to mate with whatever you used in the previous
step.
Reply to Anonymous
Well of course, most laptops are configured to go into
conservation-mode when powered by the battery.
Set your power management for max-batt-life even with AC, I'd be
curious what's the difference.
Reply to Anonymous
Boy, that sounds like tons of work.
I am saying, one of those car/airplane adapter have a step-up
transformer for 12v to 18v (typical) of what your box requires, no
12-110-18.
So u are saying the regulator circuitry built into the laptop is
inefficient and u can do better. I wanna see some comparison numbers.
Reply to Anonymous
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > QUESTION: Power Requirements
There are 994 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
