Hello all, I am currently in the process of building a budget gaming rig with the room to upgrade in the future. I currently have everything picked out except for the motherboard and power supply. I am having trouble finding parts that I think will be compatible with what I have already chosen.
With the motherboard I dont want to pick something that doesnt have all the slots I need, and for the power supply I am not sure which ones have all of the connectors that I need, and I also know that I would like it to have atleast a 400w constant power supply.
The parts that I have already selected are listed below, and I am not exactly sure that all the parts that I have picked out are compatible with each other so any advice on these parts would be appreciated also.
Processor- http://www.newegg.com/Product/Product.aspx?Item=N82E16819103706
Video Card- http://www.newegg.com/Product/Product.aspx?Item=N82E16814131330
RAM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820220435
Hard Drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
DVD Burner- http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
I am trying to only spend about $250 more on the mother board and power supply. Any suggestions on better or cheaper parts already listed would be greatly appreciated.
Thanks ahead of time for any help.
