Hello! On Wednesday, September 15th, I put together this PC. I built it to be a backup to my main PC which is similarly configured (same motherboard, i7-860):
P7P55D Deluxe LGA 1156 Intel P55 edited to add this line
[strike]ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX[/strike] edited to strike out this line
Intel Core i7-870 Lynnfield 2.93GHz LGA 1156 95W Quad-Core BX80605I7870
CORSAIR DOMINATOR 4 x 2GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) CMD8GX3M4A1333C7
Drive0 (OS) OCZ Agility 2 OCZSSD3-2AGT90G 3.5" 90GB SATA II MLC SSD
Drive1 (Data) Hitachi 0F10452 2.0TB SATA 3.0Gb/s 7200 RPM 32MB
Drive2 (Installed Apps, downloaded apps, Web site, pagefile) OCZ Agility 2 OCZSSD3-2AGT90G 3.5" 90GB SATA II MLC SSD
CPU Heat Sink ARCTIC COOLING Freezer 7 Pro rev 2 92mm CPU Cooler
O/S Microsoft Windows 7 Home Premium 64-bit
Already had on hand:
Case Cooler Master RC-531-SSN-1 Centurion 531 Mid-tower
PSU Corsair CMPSU-750TX 750W
GPU ZOTAC ZT-98GES3M-FSL GeForce 9800 GT 512MB 256-bit GDDR3
External Drive WD My Book 3.0 2 TB USB 3.0
Monitor NEC LCD2190 UXi LCD 'twist' tech.
1394b board Akumen/ NitroAV NAVPCIEFW800 PCIe 4 port Firewire 800
CF Reader FireWire SanDisk SDDRX4-CF Extreme FireWire 800
CF Card 2GB SanDisk SDCFX42048901 Extreme IV CF Memory Card
Mouse Logitech Marble Mouse USB Optical mouse PS2/USB
Keyboard Kensington K64370A 104-Key PS2 keyboard
When I fired it up I ran MemTest86+ V4.10 for a full pass (about an hour) with no errors. Installed Windows without a hitch. Began configuring it to my liking and installing applications. The next morning everything went downhill. I got blue screens and even a black screen with a note in the bottom right of the display stating that mine was not a genuine copy of Windows. MemTest went all red as soon as it started.
I'm embarrassed to admit- the RAM DIMMs were not properly seated. I assumed something about the DIMM sockets that have the clips only on one end. That is by some engineering marvel the end of the DIMM where the socket has no clip would stay down once seated. Bad assumption. As the end with the clip is being seated and the clip snaps into place the end without the clip rises up significantly. Once I figured this out I tested each DIMM in B1, then in A1 then in dual channel configurations in B1-A1. Finally I had all 4 DIMMS seated. MemTest was happy after running a full pass.
This morning I fired up the new build and- no sound. I took the plug out of the lime jack in the back panel and plugged it into line out of a laptop. Speakers work fine. Tried to figure out the VIA control panel but admit I was stumped. I tried a reinstall of the VIA driver from the ASUS setup disk but the process failed. At a point in the installation I get a dialog box that says it lists things to be done, but the list is empty. The Next button is grayed out. I removed the device and its driver using Device Manager. It went away. Then I tried to reinstall from the ASUS disk but same problem. Not sure it was the correct driver I downloaded VIA_Audio_V6017500_WinXPVistaWin7.ZIP from the ASUS site. It appeared to install OK and Via High Definition Audio is listed in Device Manager. All speaker lever sliders I can find are set to max. Still no sound.
I read the manual for the Envy HD control panel! Nowhere can I find a button that will pop up the Advanced Options dialog box. On my main PC when I am in the Speaker Settings and Test page I can click the Test button and hear an appropriate left-right sound test as well as see lever meter activity. In my new build i hear no sound and see no activity on the level meter.
Any ideas? I would be grateful for troubleshooting tips!
- Dave
- Dave
