Water cooled memory pipe?
im ordering new components for my new PC. i came across kingston hyper X H2O water cooled memory.
my big question is i have the thermaltake bigwater 760 is has a 3/8 outter dime water hose. and the hyper X H2O the pipe is 1/4" (6.35mm) I.D. fluid hose recommended.
this wont work with the pipe that comes out of the coolin block right? what can i do for a reducer can sumone PLZ PLZ help me out.
here is a link to the RAM.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6613579&sku=K24-2449
6 answers Last reply
More about water cooled memory pipe
  1. never mind the geek quad help me out. i just should have called them first since this place dont like to help after 13 looks.
  2. Its 100$ not needed. This memory is junk.. PURE CRAP
  3. sux to hear that from another person. there offering a lifetime warranty with 24/7 tech support with there ram.
    im lookin at this one now.
    http://www.ecrater.com/p/9071537/ocz-flex-ii-4gb-2x2gb#
  4. Did someone really just ask the Geek Squad for advice? lol...
    Just about every tech company offers 24/7 tech support. All you need to claim that is a website which may or may not actually have any information on it. OCZ RAM in general is pretty horrendous this generation.
    BTW, all you need is an adapter to go from 1 tubing size to another.
    ex http://www.koolance.com/water-cooling/product_info.php?product_id=108
  5. i mean common... ram that needs water cooling? Thats crazy.... just pick up some dominator with extra tall heatspeaders.
    lol yea i asked but this guy was one of the rare occasional ones that knew his ***. not one of them air headed dumb dumbs.
    i guess i just never really payed attention to other companys polices. thanks for the link man!
    ill steer clear of OCZ then i really never hurd anything about it. im on caraudio sites all the time just newer to the PC forums.
    i just like the looks of it. do i need it no but i do want it. i have dominator in right now DDR2 1066Mhz has worked great for almost 3 years.
New Build Components Memory Systems
