How does a 500GB HD suddenly turn into a 31GB HD HELP
I erased a file on my External HD but unfortunately its wiped the whole drive out and now only showing capacity of 31.9GB HELP what have i done is there anyway of restoring it???
3 answers Last reply
More about 500gb suddenly turn 31gb help
  1. Try a partition recovery application: http://www.easeus.com/partition-recovery/
  2. Thanks for the reply, just tried it but after a fast scan it says there were no partitions :-( but it did read that the drive was 698GB so i got it wrong with the 500GB its actually a 700GB.
    Means nothing if I cannot access the remaining 670GB of which 180GB of that was my family photos and movies :-( any more suggestions would be greatly appreciated, ive contacted LaCie but the support is painfully slow...
  3. How does HD Sentinel identify the drive?
    http://www.hdsentinel.com/
    Could we see the partition table and boot sector with Microsoft's Sector Inspector?
    http://www.users.on.net/~fzabkar/SecInspect.zip
    If you extract the above archive to the one folder and execute the SIrun.bat file, then this will generate a report file named SIout.txt.
    Alternatively, can you see sector 0 with a disc editor?
    HxD - Freeware Hex Editor and Disk Editor:
    http://mh-nexus.de/en/hxd
    DMDE (DM Disk Editor and Data Recovery):
    http://softdm.com/download.html
Hard Drives HD Storage
