Help with HDD problems?
I'll keep things short. I bought a new Seagate 500GB internal HDD. I installed it into my PC without problem. When I booted up the PC after the install, It froze on the first screen? It would NOT let me open BIOS, manually boot etc. It just froze. When I turned off my PC and took out the HDD, my PC booted perfectly like it did before. Also, this is a SECOND HDD for just installing games on. I already have a Samsung 250GB Installed, with my OS on it and all my other files etc.
1 answer Last reply
More about help problems
  1. you have to go into the BIOS and change the boot sequence. the machine is trying to boot to an empty drive.
    set up should be something like
    1st/HD ( the one with the operating system on it.
    2nd/DVD-rom drive
    3rd/your "new" HD.
Hard Drives Seagate Storage
