Solved
Game/work PC build help
Hi all,
another one of these :/
Approximate Purchase Date: N/A
Budget Range: 800-1000 after rebates ( a little over would be acceptable for more performance).
System Usage from Most to Least Important: Gaming (alot) (my fun), Photography software: viewing/editing etc. (my business)
Parts Required: Case/PSU/MB/CPU/Mem/GPU/HDD/CD ((OS: win 7) no need to consider in build price)
Preferred Website(s) for Parts:NewEgg. Combos..ohh, so many combos...
Country of Origin: USA
Parts Preferences: AMD prefered, Intel not out of the question at comparable price/performance.
Overclocking: not very knowlegable about OCing.
SLI or Crossfire: for the future (upgrade) or now, if price is right.
Monitor Resolution: atm 1600x900, I will upgrade that in the near future (not to be considered GPU buying-wise)( my future monitor will not be more than 27'' (or so) no big TV widescreen connections, I will want to run at the highest res prolly 1920 x 1080 - 1920 x 1200 ).
Additional Comments: No flashy cases or parts, this will be my workhorse..all business(well, play), yet it should get what I need done, cooling/performance: games (highest settings/fps possible): WoW, STO, new FF mmo, fps's, SF II, etc,. Business: graphics, CS5 etc. Lightroom, etc.
Thanks in advance.. There are just soo many nice combos (re: savings) these days, I get dizzy ( and worried) that I won't pick compatible combos in my price range.
3 answers Last reply Best Answer
More about game work build help
  1. Best answer
    ^ Here are 2 setups - 1 based on Intel and another AMD
    Both would offer similar gaming performance, but IMO Intel would offer better business performance w.r.t your requirements and also would cost more though...
    Intel -
    i5 760 + ASUS P7P55D-E Pro
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492249
    RAM -
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260
    Graphicss card
    GTX 460
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.455033
    AMD setup
    X4 955 + HD 5850
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.494180
    Or a more powerful graphics card - HD 5870
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.494164
    Gigabyte 890GX + Corsair 4GB DDR3
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492651
    Rest common
    CASE + PSU
    CM 690 Black + CM Silent PRO 700W
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.506393
    SSD for boot-
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820227542
    HDD - Data
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
    DVD
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106334
    Total - Intel - ~$991 After rebates
    AMD - ~$921 After rebates with HD 5850 | ~$981 After rebates with HD 5870...
  2. Thanks for the reply! I will look over everything when I get home from work tonight.
  3. Best answer selected by junkwa.
New Build Systems Product
