I have a friend. Whos computer use to crash only when he plays bc2 after about 5-10min. And theres no heating problem everything is normal. (as far as i know, wasnt there personally)
specs on his comp that i know
i7 920
6gb of ddr3 1333mhz
9800gtx+ in sli but has it disabled because he kept crashing and it last like 5 min longer without it on bc2.
cant remember but he has a gigabyte x58 mobo.
he has the CORSAIR CMPSU-850TX power supply.
Now his comp crashes in the simplest flash games and just turns off on him.
Other than prime 95 to check the temp of his i7. and memtest 86 for the ram to see if that works. and i have mri to check his motherboard and hdd status and cpu. is there anything i should that stresses the gpu to see the temps? if everything checks okay im guessing that the problem will be the power supply correct?
i7 920
6gb of ddr3 1333mhz
