Hi guys,
You'll have to pardon me, I'm a bit new here. Generally I just call up my dad or Google if I'm having problems along these lines, but I'm having trouble getting good information today.
Recently, my hard drive crapped out. I took it in to Fry's (under warranty) and had the hard drive replaced. Since then, however, I've continued to have problems, first with power and now with heat.
I use an HP Pavilion Elite m9350f. I've been made aware that one of the problems with this system (other than the insides being a total freakin' mess) is that it only comes with a 500W power supply, not really enough to run everything on top of a 460W graphics card (Nvidia Geforce 9800 GT). So I'm looking at replacing my power supply.
However, when I turned on SpeedFan to see what my temperatures were like before I started jacking around with things, I saw some startling numbers. I've never been good at interpreting them before, but they're definitely higher. Every single icon (except Temp2, obv.) has a flame icon next to it, just sitting here idling, with the side of the case off. Taking the side off seemed to push everything up a degree or three from these numbers:
GPU: 80 Celsius
CPU: 72
Local: 67
Remote 2: 72
Temp1: 57
Temp2: -128
Temp3: 55
Core: 57
I regularly blow out my fans, although I have no clue how to do so with the gfx card (which I've read is usable up to 105C, though I really don't want to push that.)
Before going and adding a power supply, I'd like to know what to do about my temperatures. I'm not sure which temp matches up with which meatspace component. I'm covered under my warranty still, but I wasn't having temperatures like this (that I recall) before I brought it in to Fry's. Plus, they took 29 days just to replace the hard drive*, so I'm not eager to jump back into that hole just yet.
By the by, I'm not overclocking or doing anything crazy. I just want to play some games. World of Warcraft crashes everything within three seconds of loading. Team Fortress 2 crashes everything inside of five minutes.
* for the record, they replaced my 750GB Seagate HD with a 750GB 7200RPM Western Digital Caviar Black w/32MB cache. For cryin' out loud, I even crashed one time while playing ROM CHECK FAIL (with its incredible 8-bit graphics.)
GPU: 80 Celsius
CPU: 72
Local: 67
Remote 2: 72
Temp1: 57
Temp2: -128
Temp3: 55
Core: 57
