Here's a thing that bugged me. Remember when Intel and Nvidia were so called cheating with 3dmark benches because they used modified drivers? Now here's my question what's wrong with modifying software so that can make the best use of your hardware. Ain't that suppose to be the goal?
The problem is that the benchmarks are supposed to represent the general performance of the tested hardware to other hardware under real-life usage scenarios. If you optimize the drivers specifically for a benchmark, the part looks much better relative to other parts on the benchmark than it does on actual applications. Optimizing the drivers for a specific application (such as a popular game) would be fine though, and that does happen. Look at the release notes for your GPU drivers and they'll frequently contain mention of improved performance on specific applications.
A good example of biased software are windows and the Dx api. Just have a look how a game that makes use dx 11 and all its features how it smashes a mainstream gpu which are dx 11 branded. Nvidia wanted dx 10 they pushed for it ms decided not to make a port for xp. What did it mean at the time. Back then 10 percent of the people were on vista and the rest on xp. Here nvidia brings out the Dx 10 cards everyone had to switch or forget about dx 10 which btw was more a market scheme than doing anything but revolutionizing graphics. Now its the same thing over again with dx 11.
Microsoft not supporting DirectX 10 on Windows XP was solely Microsoft's choice. It's been said that Microsoft's biggest competitor is older versions of its own software. Vista was not very well received in the market and Microsoft wanted to do anything to get people off XP and onto Vista, so not supporting the new DirectX 10 API on Windows XP was an absolute no-brainer move for them. Nobody had to switch to Vista to use NVIDIA's DirectX 10 cards as they ran perfectly fine in DirectX 9 mode under Windows XP, and the games also had DirectX 9 codepaths and would run fine on XP as well. The only people switching to Vista were really those that wanted to do so.
And yes the Dx api can slow any hardware down. Remember the Dx 9 bandwidth issue with the gaming mouses. It dragged the cpu performance down with it till some geek nailed it down and posted the fix on his blog.
I know I'm straying off the subject but seeing all this BSOD recently happening to XP users which are all kernel related due to Microsoft Updates. They even said in february that malware messed up their one update which was absurd. Luckily the update was pinpointed and could be uninstalled. Yet no update or fix for it was released.
What did you expect from Microsoft? They are not exactly known for providing the greatest-quality software.
The reason why I'm banging on about xp are due to the fact that its such a light OS which can be run with low specs. Yet a newer operating system with new more advance ways and suppose to be better ones can't be run by those users who who uses xp due to the low hardware requirements. ain't win 7 suppose to make better use of hardware? At the moment it looks like its putting a burden on it. And developers and gaming companies haven't even started to make use of dx 11 and its features.
Windows XP appears to be a "light" OS because it is ten years old. It was known to be a pretty heavy OS when it first debuted and people ran it on PIIIs, Athlons, and Willamette P4s with 128-512 MB of PC133 SDRAM, RDRAM, or DDR-266. Now that we're using quad-core and six-core CPUs clocked well over 3 GHz with more DDR3 RAM than the OS can even support, of course it will run fast. Newer OSes do take better advantage of the hardware as they use more of the hardware's features. Compare how well XP task schedules on multiple CPU cores or heaven forbid, a modern dual-socket workstation using NUMA compared to Vista or Windows 7. Its task scheduling on multiple cores is poor- remember all of the people jerking around with CPU affinity settings under Windows XP? NUMA is absolutely atrocious on XP, which is probably best portrayed by the ill-fated AMD QuadFX generally being
slower with the second CPU installed as that required the OS to use NUMA.
So we will never really know the true performance of anything. Software giants and hardware giants go hand in hand to force the people onto upgrades.
Not really. You can continue to run older versions of software on old hardware. That's what many businesses do as their old 2 GHz P4s still work for them, and so do their installations of Windows XP and Office XP. You can also run current programs on many of the free Unix clones on some very old hardware. A typical terminal-mode installation of a current Linux distribution only needs about 40-50 MB of RAM. Those OSes also have drivers for old hardware that is unsupported by current Windows installations, so everything will work as well. The only caveat is that you can really only run the complexity of programs you were originally able to run on the machine when it was new, though. You're not going to be able to run a full modern KDE4 desktop on a 1996 Pentium 200 with 128 MB of RAM. You could run a simpler window manager like IceWM, which is much closer to Windows 95 in appearance and functionality.
The biggest set back for linux was when developers stopped with OPENGL. Chronicles of Riddick was promising and it really showed the potential of it. Sadly it wasn't to be
The setback was when
game developers stopped using OpenGL in favor of Microsoft's DirectX. OpenGL under Linux works perfectly well. You can thank Microsoft for that one as they've tried to deprecate and cripple OpenGL on Windows at least once to get developers to use DirectX. Maybe we'll see OpenGL make a comeback with the rise of non-Windows machines like Apples and the myriad of ARM-powered mobile devices, almost all of which use OpenGL/OpenGL ES if they have any 3D capability (and most do.)
exactly. Why don't we see any benches on linux?
Because Tom's is predominantly a gaming-oriented site and very few AAA-list games run natively on Linux. The last one I can think of is Enemy Territory:Quake Wars (which I have
) and that came out some time ago. A good website for Linux benchmarks is
Phoronix.
