How well will this system fare $1k buyers guide
Last response: in Systems
Hello,
I was wondering how well one of the builds i found under the buyers guides works for playing games like WoW, Dragon Age, or Fallout 3.
Gamer: $1,022.89 Updated HDD
* CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGMBOX - Retail
* MOBO: ASUS M4A89GTD PRO/USB3 AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
* RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
* HSF: COOLER MASTER Intel Core i5 & Intel Core i7 compatible RR-B10-212P-GP 120mm "heatpipe direct contact" Long life sleeve CPU ... - Retail
* HDD: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
* PSU: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ... - Retail
* GPU: XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
* DVD: LITE-ON Black 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support - Retail
* Case: COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case - Retail
* Thermal Compound: Arctic Silver 5 Thermal Compound - OEM
This build will allow you to play games at mid. to max. settings at a monitor resolution of 1920x1200
Will I be able to run the upcoming expansion at maximum settings at that resolution? I know it says mid to max but for a game like Wow - Cataclysm will it fare well?
Yeah, that's a solid build. It should serve you pretty well. Are you planning on adding a second card later? If not, you could trade up in performance (for a very small amount more) to a gtx 470.
Related ressources
Ask the community
