In the past, I have always purchased a computer off the shelf and adapted it to meet my needs. I have decided that I am going to try and build one from the bottom up this time. Here is a list of my components and I am curious if I made wise choices. I am a gamer, though not necessarily hardcore. I do some photo editing and a little graphic design, on occasion. I do realize that I might have gone a little overboard in the choice of some components. I was trying to future-proof a bit and make sure that I would have a solid system for the next few years.
Here are my components...how did I do?
Computer Case
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Power Supply
CORSAIR HX Series CMPSU-750HX 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Motherboard
ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
Processor
Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
Heatsink Fan
XIGMATEK Intel Core i7 compatible Dark Knight-S1283V REV.W with ACK-I5361 120mm Long Life Bearing CPU Cooler I7 i5 775 AMD compatible
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
RAM
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224
Graphics Card
XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150477
Hard Drive (going to wait and get a SSD when they have improved)
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Disk Drive
ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Operating System
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116758
Computer Case
Power Supply
Motherboard
Processor
Heatsink Fan
RAM
Graphics Card
Disk Drive
Operating System
