After update of my sound blaster*audio extreme( for windows 7 sound volume goes
after update of my sound blaster*audio extreme( for windows 7 sound volume goes up and down. first, there was not subwoofer, than in update it starts to play, but this another problem starts!!
please help!
1 answer Last reply
More about after update sound blaster audio extreme windows sound volume goes
  1. Hmmm, the only thought that comes to mind is to completely uninstall all creative, reboot a couple of times and then reinstall to where you are happy,if you have a commercial uninstaller like Your Uninstaller, that would help a lot when uninstalling, even so there are times when you will still have to edit the registry because some programs put so much junk into it..Somebody has to pull the first rock....:)
Sound Cards Windows 7 Sound Blaster Audio Components
