Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > How are these cheap gaming pc parts?
Forum Systems : New Build How are these cheap gaming pc parts?
Motherboard - Foxconn A7DA 3.0 AM3
CPU - AMD Athlon II X4 Quad Core 640 3.0GHz Processor
GPU - Amaze Radeon HD 5850 Video Card
RAM - Kingston 2GB PC310600 (1333MHz) DDR3
HDD - Samsung 500GB 3.5" Spinpoint F3 7200rpm
PSU - Cooler Master Extreme 700W
Case - Antec Three Hundred
It is ment to play all the new games at high settings such as Crysis, Crysis 2, Black Ops, GTA4, and MW2.
Will these be good enough parts? I want to keep crossfire in the picture so thats why i got a bigger psu and crossfire ready mobo.I am also going to get another 2gb ram down the road when i get enough money.
All together it comes to around $870. I really can't go any more than that. It already exceeded what i had planned to spend.
So yeah, what do you think of these parts?
Sorry if its long :) thanks in advance!
Never go with foxconn... thats a big mistake.
http://www.newegg.com/Product/Prod [...] -_-Product
This is a better motherboard because it has the new chipset, you can upgrade to a phenom ii x6 if you want to do that in the future, it's a good reliable brand and its overall a better board.
Drop the 5850 down to a 5770 and get this ram, http://www.newegg.com/Product/Prod [...] -_-Product
Better, cheaper, higher quality case.
http://www.newegg.com/Product/Prod [...] =haf%20912
You can't beat the price of that PSU but get this.. its cables are sleeved and 50 more watts. 60Amps on the +12V rail, PFC, 80+ and three years warranty. It's all good.
Message edited by Mr Pizza on 09-23-2010 at 04:27:02 PM
Reply to Mr Pizza
This setup is pretty ideal for gaming on a budget. But it does cut a couple corners.
This motherboard uses an older chipset so you will be missing out on USB 3.0 & SATA III.
I've never heard of this brand; I can't vouch for the quality of their cards. The 5850 is a very good GPU.
Usually we recommend 4GB for a build of this price. You may be better off just selling this kit later on and buying a 2x2GB kit; mixing and matching memory kits (even kits of the same model from different batches) can make your system buggy.
Some of Cooler Master's PSUs are very low quality. That one isn't listed in the guide, so I would be wary of it:
http://www.tomshardware.com/forum/ [...] e#t2081246
It also only has two PCI-E power connectors so you couldn't or shouldn't add a second HD 5850 with it.
I would recommend one of the power supplies ranked/rated 1 or 2 here:
http://rankedpsulist.dabbledb.com/ [...] 4amps.html
------------------------------ http://valid.canardpc.com/cache/banner/1370780.png
Reply to wielander
-1 to the Cooler Master GX750, it has reviewed poorly at Jonnyguru (twice) and Hardwaresecrets.
Reply to Silvune
Ok, after updates, what bout this system?
Motherboard - ASUS M4A88TD-M
RAM - PQI 4GB (2x 2GB) PC3 10666 (1333Mhz) DDR3
HDD - Samsung 500GB 3.5" Spinpoint F3 HDD
PSU - OCZ Fatal1ty 550W
I threw crossfire out the window since by the time i would need to i would be getting an entire new system. Would this be a good gaming rig? It's REALLY pushing my budget, but if it'll play the games on medium - max settings then it's no problem. Thanks for all your help.
Reply to chloefreak17
That 880G has IGP and is mATX so if u dun need IGP have a look at the 870 chipset?
Reply to batuchka
There are 2019 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What level would you consider this?
By austinwillie_95, 2 hours ago:
It won't handle high end games that's for sure. And for $800 you would be better off just...
Best offers
Top experts
