Monitor resolution changed with dif graphics card?
My monitor's native resolution is 1680x1050, and that's what I gamed and did other stuff with.
However, I just put in my new GTX 470, and according to windows the highest resolution for my monitor is 1280 x 1024? Why would this be? Driver thing?
It shows the 1280 x 1024 under Personalization -> Display Settings.
I'm on Vista Ultimate 64 bit.
1 answer Last reply
More about monitor resolution changed graphics card
  1. Didi you install the graphics driver for the card?
    If you're using the VESA drivers, it would be limited at 1280*1024.
Graphics Cards Resolution Monitors Graphics
