Sound configuration help
hi i have a gtx 460 and using the nvidia Hd sound from the tv using an hdmi cable , and i would like to use this one with the pc built in sound card to use my pc speakers as if im using 4 speakers and 1 woofer is that possible ?
id appreciate any help :D
1 answer Last reply
More about sound configuration help
  1. if you have the necessary outputs on your onboard sound, drivers configured, then yes...
Sound Cards Speakers Configuration Components
