Archived from groups: comp.sys.laptops (More info?)
My laptop recently broke, so I took it in to some computer
specialists, and they told me that the motherboard went bad, and it
can't find the hard drive, so therefore it is impossible to startup.
They told me it would be $600 to get it replaced, but i knew that was
BS. I was wondering if anyone out there could help me find a new
compatible motherboard to buy for under $300.
I'm sure you need the system specs, but i don't have them because of
my situation. I went to the IBM website and found out what i could,
which wasn't much:
"MikeNFL15" <MikeNFL15@yahoo-dot-com.no-spam.invalid> wrote in message
news:41d5c1ff$1_2@alt.athenanews.com...
> which wasn't much:
> P(entium)3 MHz (256KB) 64MB RAM 20.0 GB 14.1 TFT 1024x768 8x-2x DVD,
> 3Com Combo, Win98
> IBM Thinkpad Laptop A21m type 2628
> I have it upgraded to Win XP pro, if that makes any difference.
> I want one that will also support a LAN (adelphia), and a modem(for
> when i'm not @ home)
> Also, the warranty is long gone, so i have no help from IBM >
> Please post if you need more system specs and know how to find them
> out
> Help will be greatly appreciated!!!!!
You could have posted more spec's, but the upshot is that you will likely
only be able to replace what's already there.
Ebay for a broken laptop of the same model. You'll need some technical
acumen to swap out the motherboard, but it can be done. I've done it, and
probably many others who post here have as well.
Keep in mind that you need a laptop with a good motherboard (ONLY). Any
other pieces you get with the deal will either sweeten the deal--to keep as
spares in case anything else breaks--or just be useless expenditure. The
only bits that might be immediately useful would be a second working
battery, more memory (if you've got free slots), or a spare power
supply...perhaps a better optical drive than the one you have.
You can get modem and LAN capabilities with USB or PCMCIA add-ons. If the
original motherboard did not have these capabilities built in (unless they
were optional, and included whatever deal you locate), then the new one
won't have them either.
>> which wasn't much:
>> 3Com Combo, Win98
>> Also, the warranty is long gone, so i have no help from IBM >>
>> out
> as
When you have your machine in hand, go to the IBM site, go to support, and
plug in the model number, which should be on the bottom, then see what
documents are available. One should be a service manual and another should
be a parts list, if it's not included in the service manual. From this you
can get the FRU numbers for planar boards that will fit your case. Then
you can try ebaying them, or ebaying for your model of laptop.
If you're looking for a third-party board, not from IBM, fuhgeddaboudid.
> jak
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
MikeNFL15@yahoo-dot-com.no-spam.invalid (MikeNFL15) writes:
I wouldn't bother. If you like the A21m so much, you should be able
to find another one in the $300 range. Try ebay or craigslist or
whatever.
The A21's still bring pretty good money.. Also theres a chance you
dont need motherboard replacement if you would like to send it in we
will diagnose it free. I do have an IBM motherboard here also w/700
Mhz CPU that may be compatable.. Will have to look at the
serial/model.
Ken
www.ikenfixit.com
