Solved
Sound won't work..
Can't get my sound to work with my new Gigabyte mobo 880g. I've updated Bios, drives, even uninstalled, used drive from cd, then from the website, and nothing. Any help please, I'm on windows 7 64bit
6 answers Last reply Best Answer
More about sound work
  1. Best answer
    Is the soundbar in your control panel grayed out? then theres a problem with the drivers.
    Make a clean install of windows.
  2. I installed that driver and nothing. :(
  3. can we have a complete spec of your machine, down to your mobo's model number?
    try to include the Southbridge chip as well
  4. I got it to work, had to clean install windows. Thanks anyways.
  5. Best answer selected by kkwik28.
  6. Glad to help!
Sound Cards Gigabyte Components
