Hello all,
Not sure what to do here:
I have installed a Noctua NH-D14 onto a Gigabyte GA-X58A-UD3R motherboard and used the y-split cable to group both fans to one power cable, as suggested. However, the motherboard's CPU FAN power socket has 4-prongs and the Noctua plug only has 3 holes. The Noctua plug does fit on the 4-prong socket on the mobo with one prong still sticking out, but that can't be right... Some of the other fan power sockets on the mobo have 3-prongs that would fit the Noctua plug (like the PWR FAN sockets). Do I leave it on the CPU FAN with one prong sticking out? Or switch it to a PWR FAN socket with the correct 3 prongs? I know others have had this board and fan, so I think there's a way (hoping). Thanks for any assistance.
Kyle
Kyle
