External HDD giving problems
Hi,
I have a 2TB external HDD (USB 3.0) that is about at 50% capacity, when I start up the pc (Running windows 8) I pick up the partitions of the drive, but it reads very slowly and also writes extremely slowly, and if I try to write large amounts of data it keeps coming up with the semaphore error. if I turn the power off and on again the disc works fine for a while (reading) but then the writing of data starts the problem again. I have defragmented the disc and ran disc check on the drive but windows doesn't find any problems with the partitions.
is there any utilities that I can use to check the drive with that wont lose any of the data that's on it or cold it be a problem with the external casing itself?
thanks in advance.
3 answers Last reply
More about external giving problems
  1. test it with the drive maker's diagnostic Windows-based software. Links here:
    http://www.tacktech.com/display.cfm?ttid=287
    I ran a diagnostic on the drive and there are quite a few errors on the drive, I done some research on the drive that I have (Samsung HD204UI) and I see there are quite a few posts on similar problems as mine concerning the same drive, and from what I can gather from the other posts I've found on this drive is there is a problem with the firmware on the drive, I've tried flashing the drive's firmware but I have not had any success in doing this, any help would really be appreciated.
  3. Do Samsung provide a utility to perform low level testing of the HDD?
    - www.samsung.com
    - www.samsunghdd.com
Hard Drives External Hard Drive Storage
