Sign-in / Sign-up
Solved
Can a Graphics Card Running DDR2 work on a PC running DDR3 memory?
  • Graphics Cards
  • DDR2
  • DDR3
  • Memory
  • Graphics
  • Product
Last response: in Graphics Cards
August 14, 2010 7:56:43 PM
Same as the title,just wondering,i dont know much about Graphics Cards.
More about : graphics card running ddr2 work running ddr3 memory
Best solution
a b } Memory
August 14, 2010 8:01:06 PM
Yes, the two things have nothing to do with each other, the ram on the video card is controlled by the hardware on the card.
August 14, 2010 8:09:06 PM
Quote:
Of course.Memory installed in gpu has no connection with ur ram.u can install it without any worry.BTW which gpu u r using still uses ddr2?
I was just browsing since i plan to buy a GPU in the near future to play mid-low end games,just tough i ask since my pc runs on DDR3 and i saw some cards with DDR2-3-5 ect. Not looking to buy anything 2 fancy 100$ budget.
m
l
a c 376 U Graphics card
August 14, 2010 9:49:10 PM
At around $100 you should be looking at one of the following;
HD5750 > GTS 250 > HD4850 > HD5670
What might limit which you can use is your power supply.
m
l
August 15, 2010 12:34:29 AM
it's 300W i can upgrade it to 400W, that should be enough for a decent 100$ card no?
m
l
August 15, 2010 1:29:15 AM
The HD5670 is alright for a 300w PSU but it is a tier below those other 3 cards. A 400w should handle the an HD5750 and if it is a good brand(Corsair, Antec, ect.) then it will handle the other 2 as well.
What it the native resolution of your monitor?
m
l
August 15, 2010 3:55:14 PM
1600x900
m
l
a b U Graphics card
August 15, 2010 4:12:32 PM
For that resolution a HD5670 is all you need for moderate gaming.
Though if you're willing to upgrade the PSU, the HD4850 would give a lot more raw performance for the same cost.
m
l
August 15, 2010 5:19:49 PM
For your resolution;
HD5770 = Great
HD5750/HD4850/GTS 250 = Good
HD5670 = Decent
m
l
August 16, 2010 7:06:19 PM
Well i plan to play mostly Guild Wars 2 when it comes out and a few strategy games, so a GPU around 100$ should be more than enough. Thanks for answering my question and your GPU suggestions. :D
m
l
August 16, 2010 7:08:37 PM
Best answer selected by kmelaza.
m
l
