Solved
Do Gfx cards switch to X4 instead of X16 if theres not enought power
do Gfx cards switch to pci-e X4 instead of pci-e X16 if theres not enought power
i have a xfx 4770....running on a antec 380watt power supply thats 3 years old
i have a asus m4a785-m board
it was fine until i look at gpu-z and it said it was running at X8 so i took out the card and put it back in and now its running at X4 and i tried everything i could to get it to x16 or even x8 and it wont
so could this card switch to x4 because it does'nt have enough power
or is it something else
7 answers Last reply Best Answer
More about cards switch enought power
  1. Nah, the power has nothing to do with that and your PSU should be fine for the card.
    Most likely you just need to reseat the card. It could take a few tries.
  2. The number of lanes it has available has no effect on its power consumption, even a PCI-E 1x slot provides 75W of power, and the 4770 doesnt need much power. I would check your BIOS settings to see if something there is slowing you down.
  3. I've had this issue due to poor seating of the card. I've had to blow air through the slot before as well. It's probably due to poor contact with the slot.
    reseted the gfx card 8 times
    i reseted my pci-e 1 card (dial-up modem)
    jump my bios 3 times
    clean out the gfx card slot 3 times
    i reseated the pci-e connector on the card
    took out the card let windows run on just the onboard video then put the card back in
    redid the graphics card driver
    redid the mobo bios
    tried the speed on pci-e to 101 mhz and 105mhz
    try to up the pci-e to 120MHZ max
    take out the mobo and put it back in
    took out ram cards to help see if voltage is a issue
    install mobo chipset drivers
    redid windows 7
    up the chipset voltage tried 1.31000V
    unplug everything from my mobo,power supply except whats needed
    and nouthing work
  5. Best answer
    Well, that is certainly thorough. The only thing I can think of is perhaps getting a can of compressed air and seeing if it can help clean out the port for a better connection.
    The good news though is that your PCIE port is 2.0 and a 2.0 slot even at x4 shouldn't really limit an HD4770. So your problem isn't really much of a problem. If the problem persists and some day you upgrade your video card than it may be an issue but still not all that much of one. Here is an article on PCIE scaling where they test using the HD5870 which is over twice as powerful as your card;
    http://www.techpowerup.com/reviews/AMD/HD_5870_PCI-Express_Scaling/
    Even on that card the difference between x16 and x4 was only 5% overall.
    hi i feel a little dumb i jump my bios again and this time left all my settings on default and its at x8 i thank its my bios they might have to update it sence i have the most upto date version i know x8 isnt that bad of a perfromance drop but x4 was i was getting black screens on gta 4 some times i just wish i knew why its doing this i might want to upgrade my card in 1 or 2 years
  7. Best answer selected by jdwii.
Graphics Cards Switch PCI Express Graphics
