ATI Radeon HD 4850x2 problems
I recently bought a new mobo Asus P5G41C-M and now the performance on my Radeon HD 4850x2 has decreased significantly. I play Champions Online and when I used to start up the game the fan speed would increase from 20% to about 30-35% now it stays at the same 20% and Im running between 10-20 fps when before I was no less than 30 fps. I increased the fan speed on my own and performance was still low. The latest drivers are installed. The device is working properly and the graphics remain the same. What could be causing this ?
Asus P5G41C-M
Intel Core2Quad Q8200 2.33 GHz
4gb DDR2 ram
Corsair 850W PS
Windows 7 64 bit
5 answers Last reply
More about radeon 4850x2 problems
  1. Not sure what was your previous motherboard, your mobo only supports PCI-E v1.1.
  2. Previous mobo was Gigabyte EG41M-S2H
  3. Try downloading all the latest motherboard updates including the BIOS, also try to disable the onboard graphics as this could be causing a problem.
    Did both still no luck
  5. Got a friend you can test the card on?
Graphics Cards Performance HD Radeon Graphics
