Alright, time to step up to the plate and junk my old HP computer. With a GTS 250 and a Intel Celeron D 360, 4 GB RAM, and a motherboard that nobody would want to touch with a 40 foot stick, PC gaming is slim to non. At least quality gaming.
I've decided to go pre-built, and strike up a new PC build (Keep in mind, I'm an uber-noob when it comes to PC building).
Here is what I was looking at, I only plan to have 1 Processor, and 1 video card. I might double the video card, but I'm not sure I would get better performance.
Ok, Am I doing this right? :
Motherboard - $140 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128435
Video Card- GTX 460 - $170 - http://www.newegg.com/Product/Produ...2&cm_re=NVidia_gtx_460-_-14-130-562-_-Product
Processor - $260 - http://www.newegg.com/Product/Produ...cm_re=amd_phenom_ii_x6-_-19-103-849-_-Product
RAM - $190 - http://www.newegg.com/Product/Produ...0145261&cm_re=2_GB_Ram-_-20-145-261-_-Product
DVD/CD drive- $20 - http://www.newegg.com/Product/Produ...VD_drive_internal_sata-_-27-106-276-_-Product
1000W Power Supply- $190 - http://www.newegg.com/Product/Produ..._re=Power_Supply_1000w-_-17-171-049-_-Product
Hard Drve - $60 - http://www.newegg.com/Product/Produ...&cm_re=750_GB_internal-_-22-148-445-_-Product
Case - $45 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
_____________________
$1075
Ok, how can I tell if I'm doing this right? Like because I look at this, and theres like stuff on there and I have no idea what it means, if it is compatible.
Also, will this stuff fit in the case? And will it be able to run Starcraft, WoW, and Crysis at high settings with 35+ FPS?
Thanks!
- Mafiaboss1337
$1075
Thanks!
- Mafiaboss1337
