Help with New Build - not sure what I need...
I am looking to build a new desktop to replace my 2005 laptop. I intend to use it for normal stuff and Photoshop editing (CS4 amateur, not for business), no gaming.
I'd like to keep costs down, but I'm thinking around $700 would be good, but that includes a monitor and Win 7.
I would like suggestions for the components . I'll list some that I was thinking about, but any input would be greatly appreciated (most of the stuff below is priced from Newegg, except the monitor, OS and case).
Monitor: 21.5" Dell U231H-, IPS panel $210
Win7: $91
Processor: Athlon II x3 445 - $78
Motherboard: ASRock M3A770DE - $65
RAM: GSkillz NS 4GB (2x2gb)DDR3 -$73
Graphics Card:
Hard Drive: WD 640GB 7200rpm -$60
Case: Antec 300 -$56
Power Supply: CoolerMaster USP100 -$30
DVD Burner: $20 Lite On
$683 + video card
Thanks for your help.
4 answers Last reply
More about help build need
  1. Links would be REALLY nice
    CPU Athlon II x4
    More cores, better performance with your Photoshop.
    Motherboard ASUS M4A88TD-M W/ USB 3.0 and Sata III
    Cheap, nice board
    RAM G.skill ECO
    Some nice G.Skill Eco With 7-8-7-24 1600Mhz
    Hard Drive Spinpoint F3 1TB
    Faster than caviar black and cheaper. Also 1TB of storage
    Graphics Card AMD Radeon 5450
    Get a graphics card so you can add another monitor later (it really helps productivity)
    $30.78 After Rebate
    Power Supply Seasonic 400w
    Cheap and a great brand. Enough for your system
    Cheap, works
    Case/OS Cooler Master Elite 341/Windows 7
    >>>>>>Subtotal: $623.70<<<<<<
    Now just add a monitor and it will be ~$750
    You can also get the HAF 912 (great airflow and cable management) for $60 off newegg
  2. Thanks, that's super helpful.
  3. Any questions? Happy to help here :)
  4. Combos to cheapen it up:
    AMD Athlon II X4 620 Propus 2.6GHz Socket AM3 95W Quad-Core Processor
    OCZ 4GB (2 x 2GB) DDR3 1600 CL7 Desktop Memory
    $149 after a $20 rebate
    GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
    Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
    $169 with promo code MBTEN923
    Rosewill DESTROYER Black Gaming ATX Mid Tower Computer Case
    Seagate Barracuda 7200.12 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
    OCZ ModXStream Pro 600W 80 PLUS Certified Modular Power Supply
    Lite-On 24X DVD Burner (Retail)
    $52 after a $20 rebate
    SAPPHIRE Radeon HD 5450 (Cedar) 512MB Video Card
    $31 after a $10 rebate
    Total (including shipping):
    $496 after $50 in rebates
New Build Systems Product
