External hard drive not working:( help!
Last response: in Storage
I had just mess up my external hard drive my restoring everything in Computer Management.. and that my computer suddent froze after 30 mins... so i restart my computer again.. when i try to plug in my external hard drive again it wont show up so i go in to Computer Management it show up that it is unknow and not initialized.. so I try to initialize it by right click and clikc that option.. it said that The request could not be performed because of an I/O device error... can anyone help me?? Thank you
"I/O device error"
This is a hardware fault and the most likely reason is that the external drive or, more commonly, the PCB inside it's enclosure has failed. You might be able to fix the problem by extracting the drive and putting it into a third-party enclosure.
boju said:
Computer freezing might be because the external hdd lost power during the process you were doing. is the power to the enclosure all the way in correctly plugged?
ya it is correctly plugged, i just can find the drive anymore, but just error disk....
