G
Guest
Guest
Trying to build an AMD gaming rig for under $1000 but one that is upgradeable without replacing a whole bunch of parts. Right now I'm totaling in at $1232.23 and trying to cut cost.
CPU and Heat Sink: AMD Phenom II x6 965 and Cooler Master Hyper 212 Plus
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.374201
Mobo and CDD: ASUS Crosshair IV Formula and ASUS DRW-24B1ST/BLK/B/AS SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.496440
Case and OS: Cooler Master HAF X and Windows 7 Home Premium
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.437504.11-119-225
RAM: G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 Model F3-10666CL9S-4GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231310
PSU: CORSAIR CMPSU-750TX
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Graphics: HIS H585FN1GD Radeon HD 5850 (Cypress Pro)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161330
HDD: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Would be happy to get down to $1100.
edit: The CPU is a AMD Phenom II x4 965 BE
edit: I found out I can get a copy of Win 7 from MSDNA so that takes that off the list and lowers the price by $90.
I am still looking at getting the HAF X though if someone could tell me how well the HAF 932 would compare for
future upgrade ability or whether it would be a good idea to go even lower with the 922 and then upgrade to a
bigger case later.
edit: What kind of thermal adhesive would you recommend?
bigger case later.
