Dell 2407WFP Issues - Please HELP
Ok built system in 05. Have been running dual displays for 2yrs now. Got 24" and now issues. Ive hooked it up VGA, DVI and if I go into like Photoshop CS4 or even just sitting there after about 3 mins. The screen goes black, green lights are still there but it locks up. Running it at native res. I hooked it up s-video and component. The resolution sucked but it was temporary. Needed to get new cable. Had no issues then. So here is what I have:
Asus P5AD2-E-Premium
Intel i925XE
Intel Pentium 4 550 @ 3400 MHz
DDR2 667 3072 MB
RADEON X700 Series
Maxtor (204 GB)
Maxtor (123 GB)
WDC (200 GB)
External WD (500 GB)
SONY DVD RW DRU-835A
Optiarc DVD RW AD-7170S
E19T6W - 19 inches
MV88SE614x PCIe to SATA2 controller 88W8310 and 88W8000G Libertas 802.11g Chipset
MV88SE614x PCIe to SATA2 controller Yukon 88E8053 PCIe Gigabit Ethernet Controller (Copper)
XP Professional 5.01.2600 Service Pack 3
DirectX : Version 9.0c (December 2007)
PSU Antec Neo 650
I have ran a 17" and 19" off of the card for two years. No issues.
General Information :
Manufacturer : ATI Technologies
Model : RADEON X700 Series
Bus Type : PCI-Express
Texture Memory : 757 MB
Processor : ATI Radeon Graphics Processor (0x5E4B)
Converter : Internal DAC(400MHz)
Refresh Rate (min/max) : 56/75 Hz
GPU Information :
Number of GPU : 1
Processor : RV410
Memory Type : 256 MB GDDR3
GPU Frequency : 425.25 MHz - [initial : 425 MHz]
Memory Frequency GPU : 432 MHz - [initial : 432 MHz]
Texels : 3200 MTexels/s
DirectX Support : 9.0
Pixel Shader Version : 3.0
GPU Configuration :
Technology CrossFire : No
GPU Timings :
CAS Latency (tCL) : 4 clocks
RAS to CAS (tRCD) : 10 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 6 clocks
Video Bios Information :
Date : 08/26/04
Catalyst : 8.591.0.0
I have tested both cables on the other single monitor and it works. I can hook up S-Video or Component on the card to run both and they work. One VGA and one DVI is when it happens. Also when I hooked it up that way and booted for the first time and after. The 19" said "Range out of frequency" until it got to windows.
More about : dell 2407wfp issues
Ask the community
