Greetings Everyone,
My main desktop seems to be in some trouble at the moment. For the last few weeks the video has been randomly shutting off (the driver halts, then tries to recover and fails, resulting in a 0x116 bluescreen), or completely freezing... as in no mouse movement, keyboard doesn't respond, and the system must be hard reset by way of the reset button. The most aggravating part of this issue, is that it only happens a couple of times a day, every 7 or 8 days. Once it happens twice, I don't see the problem again until the following week.
Specs:
Intel Core i7 920
Gigabyte GA-EX58-UD5
12GB DDR3-1600 @ 9-9-9-24
eVGA Geforce GTX 295
3 x 1.5TB Seagate 7200.11 (one is the boot drive, one is a backup volume with program installers, and the last is a buffer drive for uncompressed bluray disk rips)
3 x 1TB Seagate 7200.11 (in RAID 0)
Corsair CMPSU-1000HX 1KW
I have an additional GTX 295 card here that I have swapped in on several occasions, in case the card itself was the point of failure. Alas, it does not appear to be the issue, as the system had the aforementioned issues with the second 295 card swapped in. I have upgraded and downgraded the video drivers, but am currently running on the 260.xx series beta driver from Nvidia, and had the WHQL certified 258.96 drivers installed up until a few days ago with various other versions installed throughout this ordeal.
I have tested the PSU with a power supply tester. All voltages were spot-on, except the 5VSB which was off by .1 (still well within the 10% tolerance). I have also run MemTest86+ on a few occasions, including one session for 12 hours. No faults were detected during any of the test runs. All 6 RAM sticks have been reseated, and the slots cleaned with short bursts of compressed air while the sticks were removed. The same was done to the first x16 PCI-E slot on my motherboard when swapping the video card. The case in general - including the power supply - was cleaned with compressed air the first time this happened (about a month ago). Temperatures were also fine, as this has never occurred while in the middle of a game (only when randomly clicking desktop items, or using Alt+Tab to get back to the desktop from a full screen game), or while running anything else CPU or GPU intensive. Just for reference, temps are below:
CPU Idle:
Diode - 35
Core 1 - 42
Core 2 - 43
Core 3 - 42
Core 4 - 44
CPU Load:
Diode - 47
Core 1 - 58
Core 2 - 59
Core 3 - 61
Core 4 - 60
GPU Idle (70% fan speed)
GPU 1 - 49
GPU 2 - 48
GPU Load (70% fan speed)
GPU 1 - 78
GPU 2 - 80
As a shot in the dark, I am currently running Spinrite on all of my hard drives (except the RAID which it won't see, and I don't really want to revert the controller mode to deactivate the array to Spinrite a bunch of 1TB drives...)
None of the parts in this system have been overclocked. Everything is at stock clocks and stock voltages.
If anyone can think of something else to try that I have missed, please let me know... I would really appreciate another brain working on this one, as i'm starting to get stumped.
Regards,
TP
Specs:
Intel Core i7 920
CPU Idle:
Diode - 35
Core 1 - 42
Core 2 - 43
Core 3 - 42
Core 4 - 44
CPU Load:
Diode - 47
Core 1 - 58
Core 2 - 59
Core 3 - 61
Core 4 - 60
GPU 1 - 49
GPU 2 - 48
GPU 1 - 78
GPU 2 - 80
Regards,
TP
