How do you connect the cables for the power button, reset as well as HD led?
There's positive and negative, but the cables aren't exactly labelled properly and some are blue and white, others black and white.
I remember reading somewhere before that it doesn't matter because if they're inserted wrong then it won't work.
Thanks.
Thanks.
