Does the OCZ Fatal1ty 550w PSU have enough power for Crossfire 5770's?
Hello everyone,
I have a OCZ Fatal1ty 550w power supply (http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022&Tpk=ocz%20550w) and I was thinking about crossfiring my 5770.
Here are my specs:
ASUS p6t (not deluxe) motherboard
I7-930 OC to 3.5GHz, 1.13v (can be un-overclocked if needed)
Sapphire Vapor-X 5770 (OC to 95/1325, again, can be un-overclocked)
WD Caviar Black 1TB 7200RPM Hard drive
Antec 600 case (120mm red tricool, 200mm blue tricool, 120mm blue twocool fan)
LG WH10LSK Blu-Ray burner
Cooler Master Hyper 212 plus (one fan)
Corsair XMS3 TR3X6G1600C9 6GB RAM
OCZ OCZ550FTY 550w ATX12V PSU
I wanted to add an HIS ICEQ Radeon 5770 to this http://www.newegg.com/Product/Product.aspx?Item=N82E16814161333&cm_re=his_iceq_radeon_hd_5770-_-14-161-333-_-Product.
Will this power supply be enough for the upgrade or will I need to get a higher rated PSU?
EDIT: I may add another 6gb of Corsair RAM (same ones) maybe, but probably not :)
Please help!!
Thanks
8 answers Last reply
More about does fatal1ty 550w power crossfire 5770
  1. Should be fine you need around 450w-475w the Fatal1ty is a good psu I have one running 2xGTX460's. :)
  2. popatim said:
    I'm aware of that...but I also read somewhere that the5770's need 37 amps on the 12v rail and the fatal1ty has dual 25A 12v rails...so...idk
    Cool thanks!
  4. AMD are always going to cover themselves but knowing the rest of your system I think you'll be fine.
  5. ^The red pill or the blue pill..
  6. Thanks to everyone!!! I now have crossfire :D
    Newegg ships FAST lol everythings rock solid and it doesn't hurt that I can make all my games (bfbc2, nfs shift) have 8xAA and max settings at 1080p :)
  7. I know what you're thinking, 'cause right now I'm thinking the same thing.
    Actually, I've been thinking it ever since I got here:
    Why oh why didn't I take the BLUE pill?
Power Supplies OCZ Components Product
