AJC_55
Hello, Keep losing wireless connection on laptop. Must go to wireless connection which says connected, disconnect, & reconnect. Works for a little & disconnects again.
G
Guest
Guest
Perhaps range or interference. Experiment with channels as some work better than others in different environs.
If you can detect strong neighbouring wifi choose a channel 5 stops from the strongest.
Relocate cordless phone base or video sender away from computer or router.
