Hey there folks!
I am making a case from scratch, and recently got this switch/LED combo from eBay:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110625852464
However, bad purchase, as I don't really like the switch part of it. If I cut the switch off, and rewired the mobo connectors to a store-bought switch such as this, would it work?:
http://www.jaycar.com.au/productView.asp?ID=SP0797&keywords=illuminated+momentary+switch&form=KEYWORD
It says on the page "Rated for 250VAC @ 3A, with 12VDC LED illumination" and I'm pretty dumb when it comes to power requirements/voltages/etc of computers.
Would it also work if I connected up a similar switch to a similar mobo connector and just plugged it into the "reset pins" of the mobo?
Thanks in advance for the help!
