I have read that 32-bit operation system can hendle 4GB of Ram but mine says tha
I have read in miscrosoft.com that Windows 7 Ultimate 32-bit operation system can hendle 4GB of Ram, i have 32-bit operation system and 4GB installed but only 3.50 are usable.. can somebody tell me how to make all of it usable...! My PC:
Windows 7 Ultimate
Processor: Pentium(R) Dual-Core CPU 2.8Ghz 1.6Ghz
Installed memory (RAM): 4.00GB (3.50 usable)
System type: 32-bit Operation system...
1 answer Last reply
More about read operation system hendle mine
  1. In most cases 32-bit OS can only use 3.5 GB max. For a detailed explanation check out the link below.
    http://www.codinghorror.com/blog/2007/03/dude-wheres-my-4-gigabytes-of-ram.html
    There are supposedly ways to fix this. Try this one out:
    1) Access cmd: Click on the Start Pearl > type cmd in the Search Bar > and press Ctrl + Shift + Enter (this allows you to run cmd in administrative mode)
    2) Type BCDEdit /set PAE forceenable
    http://www.computing.net/answers/windows-7/how-can-i-make-use-of-all-4gb-ram-in-win-7/2592.html
Memory Windows 7 RAM
