Will this build work?
I'm a noob when it comes to things like this, please tell me if this build would work. Also, if there is anything I could do to make the cost lower.
Thank You!
CPU: AMD Phenom II X4 955
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
Motherboard: ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366
Video:
EVGA 896-P3-1257-AR GeForce GTX 260 Core 216 Superclocked Edition 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130433
Memory: CORSAIR XMS 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model CMX6GX3M3A1333C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145259
Hard Drive: Western Digital Caviar Green WD10EARS 1TB 5400 RPM 64MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136490
DVD: LITE-ON Black 4X BD-ROM 8X DVD-ROM 32X CD-ROM SATA Internal 4X Blu-ray Reader Model iHOS104-06 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106325
Case: Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
4 answers Last reply
More about will build work
  1. Better motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131631&cm_re=890gx-_-13-131-631-_-Product
    Case
    Consider the Haf 912
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.437504.11-119-233
    Hard Drive
    Words to not explain how much faster this hard drive will be.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&cm_re=spinpoint_f3-_-22-152-185-_-Product
    Graphics Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873&cm_re=5770-_-14-102-873-_-Product
    Ram
    The ram you picked won't work with AMD, it is triple channel and AMD only supports dual.
    Go with an i5 750/760 build if you want SLI. For sure do not go with 2XX series, go with 4XX
  2. You can save $10 and get a faster HDD if you get a 1TB samsung F3, it comes with a $16 off promo code
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&Tpk=F3%201tb
    6GB of ram isnt going to benefit you over 4GB in most applications and the 3x2 kit would make the AMD board run in single channel mode which would hurt you, i suggest dropping down to a 2x2 kit and saving ~$50
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231274
  3. Mr Pizza said:
    Better motherboard
    Case
    Hard Drive
    Graphics Card
    Ram
    I read some reviews about the motherboard you chose for me. People are saying that they had to send it in multiple times because the ones that they got didn't work. I will consider buying this one though, because others say it worked perfectly. Thank you recommending the case and the graphics, is there a higher graphics card that would work better though? $100-$175.
    Thanks!
  4. The 5830, http://www.newegg.com/Product/Product.aspx?Item=N82E16814150497&cm_re=5830-_-14-150-497-_-Product
    Would be a bit more powerful. Remember, if you want to go with NVIDIA then go with an i5.
    Wait a few weeks for the new 6000 series graphics cards from AMD, they are the nvidia 4XX fix.
New Build Systems Product
