Its an older design, and the 4 low powered 12V rails arent promising. Its got Passive PFC, which is cheaper but not used on any newer designs, its lower efficiency than a modern PSU, its not even 80+ certified, and apevia isnt a great PSU manufacturer, the 1 year warranty isnt promising when good units come with 5 year warranties. The rated wattage of a unit doesnt mean much because you dont know if they rated it at 15C or at 50C, units loose capacity as they get hotter.
I would pay a bit more to get one you dont need to worry about replacing no matter what system you use it to power. A good 500-550W unit with 40A between its 12V rails will power any system with a single graphics card for 5-7 years, that apevia probably wont make it 3 years.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004&Tpk=550vx
