Hey guys, first post here- I am from Australia but have been using your site for a lot of advice. Just looking for a little bit of help as the title suggests I'm building a new PC ordering through UMART for gaming.
These are the parts I have decided upon so far:
PROCESSOR: Intel Core i7 930 Processor LGA1366 2.8GHz 8MB Cache CPU
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=13&bid=2&sid=55456
$329
MOTHERBOARD: Gigabyte GA-X58A-UD3R X58+ICH10R QPI 6.4GT/s DDR3 2000 PCI-Ex16 SATAII SATA3 USB3.0 RAID GLAN ATX
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=106&bid=2&sid=54748
$248
RAM: Corsair TR3X6G1600C8D 6GB (3x 2GB) PC-12800 (1600MHz) DDR3 Triple Kit
http://www.umart.com.au/pro/products_review.phtml?id=10&bid=2&id2=153&sid=36374
$218
GRAPHICS CARD: XFX HD5850 1G PCIE 2D HDMI
http://www.umart.com.au/pro/products_review.phtml?id=10&bid=2&id2=82&sid=50336
$365
MONITOR: Benq G2420HD 24inch Wide Full HD 2ms HDMI DVI D-Sub Gloss
http://umart.com.au/pro/products_review.phtml?id=10&bid=2&id2=143&sid=55196
$216
POWER SUPPLY: Antec ATX TruePower 650W
http://www.umart.com.au/pro/products_listnew.phtml?id=10&bid=2&id2=140&sid=37934
$129
HARD DRIVES:????
Ok theres a fair bit of info there first of all do you think the parts I have decided upon are decent enough and are compatable/work together well?
As you can see I'm stuck on what Hard Drive to get, whether to go for 2: 1 SSD for my OS and games, and 1 SATA for other junk. Or just stick to 1 SATA (maybe the 600gb velociraptor sata3 10krpm?) or a normal seagate 7200 sata2. I'm really confused here, I don't want to overspend - will one SATA drive be enough with my specs listed above?
I also need a case - any suggestions, how many vents - 3?
Also will fans most likely be included with the case or is it necessarry to buy extra fans to be installed/if so what ones would you suggest?
Thanks in advance for your help guys!!
$329
$248
$218
$365
$216
$129
HARD DRIVES:????
