Hey guys. I was directed here by google, a guy had a similar problem to mine:
http://www.tomshardware.com/forum/246965-28-problems-building-computer
I'm having a pretty hard time with my computer. I've installed a few things into it over the last few years and this year was finally my big year to completely customize it and finish my work with it. I'm working with:
Case - Cooler Master RC-932-KWN3 HAF 932 Black Edition AT
Motherboard - Biostar TA890FXE
CPU - AMD Phenom II Black Edition Multi-Core Processor
Graphics Card - ATI Radeon HD 4870
Power Source - Thermaltake Toughpower XT 650W
Hard Drives - 2 (Western Digital 40GB & Seagate 500GB) The WD uses 4-pin & Ribbon, the Seagate uses SATA.
RAM - I have 2 pieces of RAM, they're SLI 4GB in total.
I have the motherboard properly grounded and every screw place is filled in. The next step I did was hooking in the front connections (power, reset, etc.). I have to say, the manual for this motherboard wasn't exactly great. I'll admit it's my first time putting in a motherboard, but I was careful to follow instructions from people who have being as I work in the tech field. The last motherboard I had was REALLY outdated for the type of gaming computer I'm trying to develop, so this motherboard has more than a few capabilities that are just mind boggling to me. When the power source, Graphics Card, RAM, and CPU & Heatsink were plugged in and all cables hooked in properly, I turned it on.
Lights flashed for probably .5 seconds and then it would go off. The top fan and the power source fan would spin. I looked back at the motherboard manual for a while for anything helpful on the situation. I discovered something in there that mentioned jumpers. I did what most techs do when they're looking at something new...I experimented. I'll post exactly what the manual stated because it will probably make sense to all of you reading this:
So I changed JUSBV1 from 1-2 closed to 2-3 closed. Lo and behold, I plugged the power back in and clicked the power button~BAM. Computer powered on nicely and all fans were spinning. The little BIOS POST CODE/CPU Temp. indicator lit up and read "d4". I looked up d4 in the book and nothing. If I looked online, I believe other motherboards would have different codes for all sorts of things, but one motherboards d4 meant some type of malfunction. I powered it off for a while, came back later and turned it on again this time to see a different code (I forget, but this code was still not listed in book). I clicked the reset button on the motherboard and now it's code has been staying at "60" or "b0" I guess. In the book 60 means it's initializing NUM-LOCK status. b0 isn't even in the book.
I ran out and got a different keyboard, something more standard, because mine wasn't working or even lighting up. I know my keyboard has drivers to be installed with it (Lycosa Razer keyboard). The mouse is a gaming mouse as well, didn't light up. The screen is blank. No BIOs, nothing. Beeping like all hell. I plugged the new keyboard in and mashed "delete" hoping the BIOs screen would pop up eventually, but it never did. Oddly enough, this is when I realized the heatsink fan wasn't moving and the fan on the side isn't moving as well. I unplugged the fan from the bottom of the motherboard (SYS_FAN1), and plugged it into SYS_FAN2 near the top. It worked. I was concerned about my CPU since I hadn't noticed the heatsink not working and I took it off right away. It was hot, but not scorching. The fan right above the CPU and the other side had been working so I'm hoping it provided some type of ventilation for it. Now I'm nervous to turn it on more than 5 seconds because obviously the CPU works, I don't want to overheat it.
I took out a piece of RAM and the heatsink started turning again. The side fan that wasn't working twitched and when I flicked it....it worked. I just unplugged all my hard drives and was told the keyboard I picked up (USB Keyboard) wouldn't work, I needed a PS/2 keyboard. Also, I don't have a VGA hookup. My graphics card only supports DVI.
Does anyone have any ideas as to why this is happening? I can post as much info as you need, I just want to get this together. Please help!
Code:
[B]JUSBV1/JUSBV2: Power Source Headers for USB Ports[/B]
[I]Port 1-2 Close:[/I]
JUSBV1: +5V for USB ports at USB1/USB_1394_ESATA1/RJ45USB1.
JUSBV2: +5V for USB ports at F_USB1/F_USB2/F_USB3.
[I]Pin 2-3 Close:[/I]
JUSBV1: +5V STB for USB ports at USB1/USB_1394_ESATA1/RJ45USB1.
JUSBV2: +5V STB for USB ports at F_USB1/F_USB2/F_USB3.
