Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Required Power supply for ATI 5770
Forum Graphics & Displays : Graphics Cards Required Power supply for ATI 5770
Hi every one this is Indrashis
I am going to buy an ATI 5770 1GB GDDR5 GPU soon....I'm kind of low on budget so if I buy a Imigo 500wt PSU,will it do any harm???later on i can switch to a decent one
Reply to indrashis95
Can't you get a 450W PSU from Corsair or Antec?
Reply to unknown_13
No, get a Fortron 400W or something. Any site with PC parts in your country that you can give the link?
Reply to mosox
Whatever it is get something good. Even if you are on budget. Don't compromise on PSU. It will do you more harm than good.
Reply to hell_storm2004
The PSU is the part that is supplying power to your system and is not a part to go on the cheap side with --why risk having it blow up and take the rest of your expensive hardware with it just to save a few $'s ---- In the long run that can cost you alot of $'s to replace an entire system because a cheap PSU with no circuitry to prevent Overvoltage winds up taking down your CPU, Video Card, Memory Modules, and MOBO because you saved a couple $'s !! Stick with a decent PSU from a reputable brand - esp. considering the Power Requirements of a system based on a 5770 GPU is not that excessive so a fairly inexpensive but good quality PSU can be found without spending a lot !
Message edited by JDFan on 08-18-2010 at 03:52:27 PM
Reply to JDFan
Where do you get your computer parts, as mosox said.
Stick with brands like Corsair, Seasonic, PC Power and Cooling, Tangan, OCZ, (new) Antecs. If you get a brand like that you will be fine with a 450w PSU.
------------------------------ |CPU| i7 920 @ 3.8Ghz |MOBO| Rampage II |RAM| 12GB, 6*2Gig GSkill DDR3 |GPU| EVGA GTX 260 x2 SLI
|HDD| 300GB VelociRaptor + 2*1TB Caviar |Sound| X-Fi Titanium Fatal1ty |PSU| Corsair 750TX
|Case| XCLIO A380BK |CPUCooling| Zalman CNPS 9000 |OS| Vista 64
Reply to Helltech
In the countries that are not rich only those who get an i7 930 system buy Corsair, Antec or Seasonic.
If he has the money he can get one of those but otherwise there's lots of good much cheaper brands and it's crazy to get, say a Corsair PSU and a GTS 240 when you can get with the same money a Fortron and a HD 5770.
Fortron, Rasurbo, Sirtec, Gigabyte, Spire, Recom, Silver Power, Cooler Master, Super Flower. etc etc are common in these parts.
Reply to mosox
There are 2043 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bad PCI-E Slot or Bad Graphics Card?
By smorizio, 34 minutes ago:
check that you have all the power cables plugged into your video card..some have one some...
Best offers
Top experts
