Is a higher speed RAM is harmful for a lower speed processor?
Hello,
i just want to know generic question's answer from you that - is a higher speed RAM is harmful for a lower speed processor if I am not changing the processor speed internally to that of the RAM i.e. if I am not making any changes then....! say I am installing 1333MHz RAM for 800MHz Processor. Will this harm the system? I do know the useless though but will this harm the system in any possible way/s?
1 answer Last reply
More about higher speed harmful lower speed processor
  1. No harm will come as a result of doing as you are suggesting. The system will default back to a "least common denominator" is terms of synching devices to work together. No harm will come from this.
    Good luck!
Corsair RAM Processors Memory
