New Build need help
I just started my first computer build.I was given a motherboard, and an amd2x4 processor 2.8ghz.
So to get to the point i have a bestbuy gift card and need to know what video card to get for around 65$, and also what power supply, can i get a more powerfull one than need for maybe a future upgrade or will that hurt the system?And should i even worry about crossfire?The only things i will be doing is playing world of warcraft and running CS4(one monitor)?
Components i have already/
Gift card $200
Gigabyte GA-785GM-us2h motherboard(intergrated graphic and modem, sound also)
2gb ram ddr2
harddrive
case has one 21 fan
AMD2-quadcore 2.8ghz and fan and heatsink
case says takes normal atx power supply
Need
video card
power supply
dvd rom
4 answers Last reply
More about build help
  1. I would get this power supply-------> http://www.bestbuy.com/site/Corsair+-+Gaming+Series+600-Watt+ATX+CPU+Power+Supply/1073679.p?id=1218217268656&skuId=1073679&st=power%20supply&cp=1&lp=6
    and just worry about using one good video card. It's not necessary to crossfire/sli on one monitor especially for just WOW.
    For video card grab this-------> http://www.bestbuy.com/site/EVGA+-+GeForce+GTS+450+FPB+1GB+GDDR5+PCI+Express+2.0+Graphics+Card/1700595.p?id=1218282104676&skuId=1700595&st=videocard&cp=2&lp=11
    That's around 200, you can add a dvd rom for around 20 almost anwhere, maybe cheaper on Newegg.
  2. Don't worry about crossfire for your needs.
    It's too bad you have to use that gift card. Best buy over prices their video cards.
    dvd rom http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
    power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016 you always want a good name brand and you could always upgrade your card and need more power
    a cheap video card for around 65?? http://www.newegg.com/Product/Product.aspx?Item=N82E16814161315
    not many choices.
    remember the video card had to be 65 dollars!
  4. I understand but he has a 200 gift card, what is he going to do with the rest of it, buy paper? Besides a decent card for 65 doesn't exist.
Components Product
