Question regarding power supply
hi guys,
for the first time i'm building my own pc "from the scratch".
the components are as follows:
SPE 4096MB G.Skill PC3-10666-4GBRH CL7 KIT
COL Scythe Kaze Jyu Slim 100x12mm 2000U/m
HDD 3.5" Samsung SpinPoint F3 500GB HD502HJ 7200U/m
DVD LG Electronics (B) GH-22NS SATA schwarz
CPU AMD Phenom II X4 945 3.0GHz - Socket AM3 BOX
MBP ASRock N68-S3 UCC AM3
Geforce XFX 8800gts fatal1ty
as power supply i plan to use my old
be quiet Straight Power BQT E6-500W PC Netzteil ATX 2.2 500 Watt .
i heard various opinions wether this enough or not.
can you help me and tell me how to calculate what i really need?
thanks in advance
4 answers Last reply
More about question power supply
  1. Should easily be enough
  2. For your first build, make sure you hear both ram module CLIP on your motherboard.
    Also, make sure your fans are blowing on the good direction.
    Last but not the least, come back if you have any trouble with your computer, it will be a pleasure to help you !
    T: Your power supply as stated above, should be plenty for your 8800 ... If you plan on going for a second one, you might want to go for a 600-700 watts psu instead.
    But for now, enjoy !
  3. For first-time builders, I recommend looking at these threads:
    Build it yourself:
    http://www.tomshardware.co.uk/forum/274745-13-step-step-guide-building
    And although this primarily a troubleshooting thread, the first part contains a checklist that will catch most noob mistakes:
    http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
Homebuilt Power Supplies Systems
