Solved
4 pin molex power from usb
Last response: in Components
Thanks guys, all those are really great. But I already knew about them, and wanted to know if I could get enough power for the drive from the USB. If not, the external ac adapter was my plan B, but buying something pre-made is never as rewarding as when you solve a problem with a DIY!
Related ressources
shovenose said:
you can do something like this (sory its ugly it only took me a few minutes) :)
Thanks shovenose, I taught about doing it like that (5V to 5V and GND to GND), but where does that leave the 12v (yellow) in the molex? Can the drive still get power without it?
AS for data, I already have a 3.5 bay with an external sata connector, so that's not a problem... and since my usage is mostly in DOS, I best avoid USB.
Power supply Authority
I'm a little confused, I thought your OP said you wanted to connect your laptop drives to your PC via USB but you were trying to go usb to 4 pim molex then 4 pin molex to sata??
Or have I got it wrong coz you then said you need to stay away from usb??
Or is it that you just want to make your own rather than let someone in HK do it for you? :pt1cable:  ? [:fixitbil:1]
Ask the community
