Hey guys, I just purchased another GTX 460 for my tower and I haven't been able to run all my fans and my lcd display on the antec case after I switched connections.
it used to work fine if I plugged the second card to the shared molex conectors (linked with the fans, etc) and I used to overclock both 460s but then I read somewhere that that's not the best connection for performance,
when I use a 6 pin cable straight to the second card then 3 of my led fans will not run and if I plug them then the system boots up and dies 30 secs after booting, my question is should I replace my PSU? I have a OCZ 500w modxtream pro
I have EVGA SLI mother board,
Intel 920 i7
2 gigs Corsair
antec 902 case with 4 + 1 extra led fans.
SATA hard drive WD
1 dvd rw drive
1 small led fan monitor
Thanks
Intel 920 i7
2 gigs Corsair
SATA hard drive WD
1 dvd rw drive
Thanks
