Do i need a bigger power supply?
This is my build currently:
HDD: SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822152181
CASE: Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811129058
CPU: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor: http://www.newegg.com/Product/Prod [...] -_-Product
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) - http://www.newegg.com/Product/Prod [...] -_-Product
MOBO: ASRock 870 EXTREME3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813157198
PSU: OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] 6817341022
CD/DVD: SAMSUNG 24X DVD+R 8X DVD+RW 16X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 4X CD-RW 48X CD-ROM 2MB Cache SATA 24x DVD Burner - Bulk LightScribe Support - OEM
http://www.newegg.com/Product/Prod [...] 6827151216
EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595&cm_re=evga_gtx_570-_-14-130-595-_-Product
I am about to order a new case for myself because the one I have is to small. I think I may need a new PSU but I am not sure. I calculated about 500W needed but I just want to be sure.
6 answers Last reply
More about bigger power supply
  1. Yes I think you'll be ok with that psu.
    I'd take the 1200 over the HAF932 but the HAF-X over the 1200.
    I'd take this over both of them - http://www.newegg.com/Product/Product.aspx?Item=N82E16811163154&cm_re=silverstone_raven-_-11-163-154-_-Product
  2. I am really digging the HAF-X :D
  3. If thats the one that does it for you then get it.
    You'll be glad you did everytime you look at it. ;)
    What about its crazy looking brother - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119236&cm_re=HAF-X-_-11-119-236-_-Product
  4. lol thats a cool case - i wonder how much nvidia paid them :)
Power Supplies Components Product
