so i previously posted a thread about a system build i was planning on doing using a cheap biostar mobo
and asked the community to help, and you did, thanx.
a couple of people told me not to use the biostar mobo for it was cheaply made, so i decided not to use it
i also downgraded from a phenom ii x6 1055t to, well read the rest for details
im now using these parts as my future system build
amd phenom ii 965be at 3.4ghz - cpu
ASUS M4A785TD-M EVO - motherboard
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 F3-10666CL8D-4GBRM
and some random hdd and dvd writer from newegg thats not really important
i already bought my antec 600 case and a 550 watt continuous modular psu
i will be using the onboard graphics card for awhile but will upgrade when the money rolls in
this is a budget build by every definition (around 450$) so i dont expect it to run anything new,
(so i ask you experts here at toms hardware if this is a fairly good build?) i would appreciate some feedback,advice, or suggestions thanks guys)
