G
Guest
Guest
I'm building a new system right now, but having trouble getting the bios or anything else to show up on the screen.
Currently all the case fans turn on, the GPU fans turns on, hard drives sound like they're turned on and the DVD/RW is powered as well.
The CPU fan does not turn on. Yes, it is plugged into the correct slot in the motherboard.
I get a long series of short beeps which my motherboard manual tells me is a "power error".
I dont think it's a case of a lack of power for the system, I have an i5-760, 1HDD, 1 optical drive and a gtx 460. The power supply is a Coolermaster GW 650W. Certainly that should be enough power, right?
I'm concerned with some of the power cables on it. It has one of those 20+4 pin connectors for the main motherboard power. And the CPU is 8 pin on the motherboard, but the only ones on the power supply that I can use are two side by side 4 pins (yellow/black corded ones).
Would that be incompatible? What combinatino should they be plugged in? I've a few different combos to no avail. I think that all 8 CPU plugs have to be filled but that I could get by with just 20 on the 24, but I've also put in all 24 and it doesn't help.
Cleared the CMOS, checked all the wiring and basic setup on the computer, re-mounted the CPU.... I'm out of answers unless my PSU is broke or I bought the wrong one
