I am having problems trying to delete my pagefile.sys. I am running a 64gb SSD as my OS disk and I only have 4 gb left because of the paging file. I have 16gb of RAM in my computer and it is use 14.5 gb of it in the paging file. I know that it is a relatively straightforward process of deleting it, but it does not work for me. What i had done to try and remove it is go under the virtual memory settings and change it to "No Paging File". I restart the computer and my C drive does not show a change in empty space. But the weird part is that it does not show up when I look at C:\ under the windows explorer (obviously with hidden files showing). Although when I use the program FileTreeSize to view the drive, it still shows up. When i try and manually delete it under the FileTreeSize, it wont let me because it says that it is being used. I am not really sure what to do at this point because I have taken all of the steps that would normally delete it, but i cant seem to get rid of it. Is there another way of getting rid of it that I do not know of? I would greatly appreciate your help!
Cheers
Cheers
